FPGA Intellectual Property
6670 Discussions
What clock sources are allowed for an EMIF reference clock?
KCMurphy
I need to generate a 200MHz reference clock for an LPDDR3 EMIF.  If I don't have any convenient clock available, how can I generate it on chip?  There seems to be an issue with using a PLL output as the reference source of an EMIF.
The Altera-ese that I get in the error description is not particularly helpful.  Does this signal have to come externally, or can I generate it somehow internally.
Arria 10 10AX022C3U19I2SG
Quartus Pro 21.3.0
EMIF 19.2
AdzimZM_Intel
Hi KCMurphy,
The EMIF IP need to be driven from a dedicated clock source.
It's cannot uses the internally generated clock to drive the logic.
Adzim
KCMurphy
And that dedicated clock has to be in the same bank as the EMIF block?
AdzimZM_Intel
Hi KCMurphy,
"And that dedicated clock has to be in the same bank as the EMIF block?"
  • Yes it's must in the same bank as EMIF block
Adzim
AdzimZM_Intel
We do not receive any further response regarding to this topic. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
