FPGA Intellectual Property
6670 Discussions
When I run simulation of a rapidio qsys,there is a error occures,but why it is happening?
LWANG128
When I run simulation of a rapidio qsys,there is a error occures,as this:
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
Vicky1
Which Quartus edition & version are you using?
Have you tried by regenerating the IP & simulation model for that IP in presently used quartus tool?
Could you provide *.qar project file ('Project ' Menu->'Archive Project') replication purpose?
Vicky
Vicky1
May I know any update?
Vicky
