FPGA Intellectual Property
6665 Discussions
Why is the HPS EMAC Interface splitter emac_tx_reset input associated with the emac_gtx_clk?
JWils26
The emac_rx_reset is associated with the emac_rx_clk as one would expect, so why is the tx_reset not associated with the tx_clk? I traced it through the code and it is not clear why it would be like this.
FawazJ_Altera
Hello, can you please share with me the piece of code that you have found? thanks
JWils26
In the altera_hps_emac_interface_splitter_hw.tcl file:
# connection point emac_tx_reset
add_interface emac_tx_reset reset end
set_interface_property emac_tx_reset associatedClock emac_gtx_clk
set_interface_property emac_tx_reset synchronousEdges DEASSERT
set_interface_property emac_tx_reset ENABLED true
add_interface_port emac_tx_reset rst_tx_n_o reset_n Input 1
FawazJ_Altera
Thank you very much for your sharing, I will go through that with my internal team and reply to you ASAP. Thanks
