FPGA Intellectual Property
6673 Discussions
XAUI core simulation for Cyclone V
I'm simulating in Modelsim XAUI Phi core generated by Megawizard for Cyclone V. I use QII 13.0.1.
This is a stand-alone simulation (core only)
The problems:
1. No stimulus in the simulation files, generated by Megawizard, only "bare" XAUI core called for simulation.
2. When I added stimulus generation module, signal phy_mgmt_waitrequest, set to 1'b0 by reset, set to 1'bZ in every phy_mgmt bus read/write attempt
3. channel 3 of XAUI output becoming undefined soon after simulation started.
Anybody have the same problems or may be give any suggestions, advices, solutions???
Thanks for all! Problem is solved, solution is here: http://yadi.sk/d/s2kbxtjtefkoc
