always @ (posedge clk or negedge alarm_in)
begin if(cnt_s == set_s && cnt_m == set_m && cnt_h == set_h) alarm_outr <= 1'b1; else if(alarm_in == 1'b0) begin alarm_outr <= 1'b0; end e Error (10200): Verilog HDL Conditional Statement error at timeinterrupt.v(43): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct but if i change" posedge clk or negedge alarm_in" into "clk or alarm_in" it will be ok but it will warrning ,Warning (10235): Verilog HDL Always Construct warning at timeinterrupt.v(103): variable "cnt_h" is read inside the Always Construct but isn't in the Always Construct's Event Control how to handle this problem?Link Copied
It is not possible to synchronize on both positive and negative edge of a clock. Evene worse if you want to trigger on two clocks.
I suggest to synchronize everything on one clock. Then start with a check on the condition being zero for the remaining signal.- Mark as New
if i have two signal to determine the outcome, i can't put the outcome variable into two always blocks.... so i have to put them into one always block
for : always @ ( in1 or in2) if (in1=1) a =b ; else .... i can't change them into always @ (in1) if (...) a=b ; always @ (in2) if(...) a =d so there is always some time i have to put some clock in one block; if i put them into one block,then i meet the problem like the previous one do u have good way to design or handle this situation? i try this way: alarm = ((cnt_s == set_s) && (cnt_m == set_m) && (cnt_h == set_h))? 1'b1:alarm_in; the same logic however it still warning this: Warning (10236): Verilog HDL Implicit Net warning at timeinterrupt.v(116): created implicit net for "alarm" :confused::confused::confused:- Mark as New
I think that your idea of :
for : always @ ( in1 or in2) if (in1=1) a =b ; else .... works if you put only the signals in the sensitivity list of the always block. This generates a combinatorial function not triggered on any clock. Further, the lasty line of code that you propose: alarm = ((cnt_s == set_s) && (cnt_m == set_m) && (cnt_h == set_h))? 1'b1:alarm_in; is also good. The warning that you get is because you did not define a wire for the signal alarm. Add the wire declaration and it should be fine. --- Quote Start --- if i have two signal to determine the outcome, i can't put the outcome variable into two always blocks.... so i have to put them into one always block for : always @ ( in1 or in2) if (in1=1) a =b ; else .... i can't change them into always @ (in1) if (...) a=b ; always @ (in2) if(...) a =d so there is always some time i have to put some clock in one block; if i put them into one block,then i meet the problem like the previous one do u have good way to design or handle this situation? i try this way: alarm = ((cnt_s == set_s) && (cnt_m == set_m) && (cnt_h == set_h))? 1'b1:alarm_in; the same logic however it still warning this: Warning (10236): Verilog HDL Implicit Net warning at timeinterrupt.v(116): created implicit net for "alarm" :confused::confused::confused: --- Quote End ---- Mark as New
Referring to your original code snippet
begin
alarm_outr <= 1'b1;
alarm_outr <= 1'b0;
end
It does not involve dual clock edges as supected by nplttr, because alarm_in isn't a clock. The code uses the Verilog syntax for an asynchronous reset, but with a wrong order (and unpaired begin end). This way it should synthesisze correctly. If you think the order of the original code is essential, then you have a problem... always @ (posedge clk or negedge alarm_in)
begin
alarm_outr <= 1'b0;
else
alarm_outr <= 1'b1;
end
Generally, you should consider that an edge sensitive always block stands for a DFF, possibly with additional asynchronous inputs. It can be driven by only one clock. So one register can't appear in multiple always block as assignment target.
thanks i tried your way to design .... it can synthesized ... thanks again
thanks very much ...you give me another ideal to design ...
Topic Options
