FPGA Intellectual Property
6673 Discussions
altmemphy AFI and DFI
hi,all
Now i use a ddr mem controller IP ,and this IP's interface is denalli DFI interface; but altmemphy's interface is AFI;
how can i use altmemphy connect with my ddr mem controller IP in altera fpag simulation;
thanks!
who can help me
Do you have answer about which DFI spec. the AFI compliant with?
Does your controller use the training features of the DFI interface? If so you cant use it with AFI as AltMemPHY's calibration is enclosed within the PHY. Other than that the signals pretty much line up one to one. I think there is one extra signal left in AFI but that can easily be generated in logic.
Why do you want to use Denali controller? Could you just use Altera's controller?
I also use DFI controller and with a DFI PHY on an upcoming ASIC. However, we would want to verify our system in FPGA. The PHY is afterall doing something related to timing but the actual protocol verification is on the controller. I would want to verify the system with my controller but using Altera PHY. To do it, I have to interface controller DFI to AFI Altera PHY.
The DFI specs I am using is DFI2.0.
I use Xilinx FPGA before and able to create a DFI wrapper onto xilinx PHY but my company wanted to move to Altera. I hope the team here can assist.
Can you also supply me the link to see Altera AFI specs? The controller is DDR2 now and my upcoming one is DDR3. Do Altera FPGA support DDR3 PHY ?
Hope to hear from you as soon as possible.
Thanks!
Mr Lim
Kingsleyhng
Hello Mr lim, i'm interested on your DFI wrapper on xilinx phy. Could you leave your email, so that i can contact you?
DFI is not supported by Altera, you could possibly do it with restrictions, as mentioned above.
Altera does have DDR3 PHY. 533MHz in Stratix IV
AFI is documented in the EMI handbook on the web site.
DFI been a DDR standards by industry. Is Altera looking into making the PHY AFI? Xilinx V6 has DFI PHY. Do Altera support a DFI wrapper onto AFI interface PHY?
I dont know what Altera's plans are.
How did you resolve this issue?
Hi all guys,
I also encounter this problem, have to connect DFI 2.0 memory controller (Denali IP core) to AFI PHY and realize it on Altera FPGA.
Anyone can provide a feasible solution to resolve this problem?
Thank you very much!
Qian
Here is the pin connections
control interface
dfi_address => ctl_addr
dfi_bank => ctl_ba
dfi_cas_n => ctl_casn
dfi_cke => ctl_cke
dfi_cs_n => ctl_csn
dfi_odt => ctl_odt
dfi_ras_n => ctl_rasn
dfi_reset_n => ctl_rstn
dfi_we_n => ctl_wen
write interface
dfi_wrdata => ctl_wdata
dfi_wrdata_en => ctl_wdata_valid
dfi_wrdata_mask => ctl_dm
Also need to add logic to generate a ctl_dqs_burst signal
read interface
dfi_rddata_en => ctl_doing_read
dfi_rddata <= ctl_rdata
dfi_rddata_valid <= ctl_rdata_valid
status interface
dfi_init_complete <= ctl_cal_success
dfi_dram_clk_disable => ctl_mem_clk_disable
for ctl_dqs_burst you need to use the dfi_wrdata_en signal but delay it depending on what sort of AFI write interface you are using. Full rate, half rate, odd or even alignment. The required waveforms are listed in Altera's external memory handbook.
thanks for your explanation but what about the update interface of DFI interface (dfi_ctrlupd_req, dfi_phyupd_ack, etc.) ? it doesn't seems to be optionnal.
No, Altera's PHY solution doesn't have an equivalent feature or capability.
May I ask why would you need this?
Hi, thanks for your answer.
I don't know if I need update interface of the DFI 2.1 interface. I don't know if this interface is needed to have my ddr2 controller working.
Anybody connect DFI with ALTMEMPHY successfully?
What kind of ALTMEMPHY to choose, Half-Rate or full-rate?
