FPGA Intellectual Property
6669 토론
calibration of ddr4 interface on 10AX066H4F34E3SG
Andrey_Fazan
초보자
6,828 조회수
Hello! I'm trying to implement DDR4 40bit-wide interface with 3 devices MT40A512M16LY-062E. When I connect only one of 3 devices to the project, calibration and data exchange do well, but when I connect all 3 devices - calibration fails. Why it happens and how can it be fixed?
0 포인트
26 응답
AdzimZM_Intel
직원
1,507 조회수
Hi Andrey,
Thank you for sharing those files.
It's looks like the sdram_a cannot be worked when enabling 16bit and combing with other memory.
I'm not sure what is the reason for that but I think it's could be related with the voltage.
So can you probe on your board at the sdram_a[7...0] and sdram[15...8] to analyze the voltage?
Adzim
0 포인트
yoichiK_intel
직원
1,497 조회수
Hi
just to make sure , do you use the 240 resistor as RZQ resistor on your board ?
0 포인트
AdzimZM_Intel
직원
1,460 조회수
Hi Andrey,
Do you have any update on this?
Adzim
0 포인트
Andrey_Fazan
초보자
1,378 조회수
Hi, Adzim
Is it possible to get PCB layout of arria 10 soc development kit? It could help us check if our layout of DDR4 devices is correct.
Thank you!
0 포인트
yoichiK_intel
직원
1,360 조회수
0 포인트
Andrey_Fazan
초보자
1,427 조회수
Hi!
just to make sure , do you use the 240 resistor as RZQ resistor on your board ? - Yes, we use it
So can you probe on your board at the sdram_a[7...0] and sdram[15...8] to analyze the voltage?Everything with voltage is fine, but we need to update our board, so I will tell later about results
Thank you!
0 포인트
응답
