FPGA Intellectual Property
6670 Discussions
clocked video input => clocked video output
Hi all,
in the last few days I tried to set up a small environment for easy input/output HD/SDI video signals using the altera video IP suite. And actually I have some troubles where I really need help...
1) clocked input video status registers:
My input is a HD/SDI signal 1080i/50 from the gennum receiver Chip GS2970. When I read out the Status Register from the clocked video input via Console I got the following answer:
0x00000000 - Address 0 - Control
0x000005d8 - Address 1 - Status
0x00000000 - Address 2 - Interrupt
0x00000000 - Address 3 - Used Words
0x00000780 - Address 4 - Active Sample Count (1920)
0x0000021c - Address 5 - F0 Active Line Count (540)
0x0000021c - Address 6 - F1 Active Line Count (540)
0x00000a50 - Address 7 - Total Sample Count (2640)
0x00000232 - Address 8 - F0 Total Line Count (562)
0x00000233 - Address 9 - F1 Total Line Count (563)
0x00000000 - Address 10 - Standard
0x00000000 - Address 11 - SOF Sample
0x00000000 - Address 12 - SOF line
0x00000000 - Address 13 - Refclk
All Values from address 4 - address 9 seem to be ok. Bit 10 of the status indicates a valid resolution and bit 8 indicates that the video stream is stable.. But I am wondering why the status register is not set to 5F8? in other words, bit 4 (F0LineCount register) is not valid even though address 5 and address 8 seem to be correct? Do anyone have a hint how to solve this problem?
2) clocked video input ===> clocked video output. Do I need any frame buffer between the two IP's?
3) Actually I can not communicate correctly with the clocked video output via console. When the Go bit is set to '0' I read all registers set to '0' and when I write to a register, the value is not set by reading it afterwards. What could be the problem for that?
Thank you for helping me out.
Hi all,
just for all with the same troubles: problem 3) solved:
Note to table 10-8 in clocked video ouptut megacore function: "all of the moden registers are write only", there fore assigned values cannot be read back.
Did You get answers to Your 1). and 2). questions?
