FPGA Intellectual Property
6672 Discussions
confusion about scaler
hi,
I have a problem with scaler, my data path is :
CVI(clocked video input)->SCL(scaler)->FRM(frame buffer)->CVO(clocked video output)
It takes the input resolution 800x600 and scaled to 1920x1080 and output , when the input is 800x600, it worked well.
But when I changed the input resolution from 800x600 to 640x480, the whole screen flickered badly.
So I think the input resolution of scaler is fixed, am I right?
Thanks for reply!
If you use the Scaler as is (without controlling it via the run-time control) then the input is fixed per the configuration in the SOPC.
If you use the run-time control then the input resolution is the maximum resolution you can input.
BR,
Reuven
--- Quote Start ---
BR,
Reuven
--- Quote End ---
hi, ra2m, thanks for reply.
do you mean if I use the run-time control of scaler which means I can input other resolution equal to or less than the maximum resolution I set in sopc?
But it seems that there is no register of scaler for me to explictly change the scaler to adapt to the input resolution at run time.
Yes, when the run-time control is used the input resolution in the SOPC setting is the maximum resolution. Any resolution below the set input resolution it will be scaled.
But if the run-time control is not used the input resolution in the SOPC is the only resolution that can be used in the input.
BR,
Reuven
You should probably check the following thread since this seems to be the system you are trying to implement:
http://www.alteraforum.com/forum/showthread.php?t=21066&page=1
It is mentioned that the CVI could have some issues with some DVI inputs. This could explain the flickering in your case.
