FPGA Intellectual Property
6673 Discussions
constraint in a custom sopc component
Hi, i did a macro that enhance the contrast of an image. I have implemented as a sopc custom component.
It has a pll inside that doubles the frequency for some elaboration and then i return to the normal frequency before output the results.
I have 3 parallel channel for R G and B elaboration.
If i use signal tap for watching the red channel, i see that the red data flows stable to the output instead of the green and blue data that give me some wrong results.
I think signal tap is adding some constraint to the red channel and this helped.
How i can constraint better my macro?
In input i have the SOPC system clock.
Is the internal clock related with the SOPC system clock? I think yes so i don't understand why i have these timing problems.
Thank you
