FPGA Intellectual Property
6670 Discussions
control packets issue in dsp builder
Hi
I am working on video and image processing project.
I am using quartus II v6.0 and dsp builder.
I have used deinterlacer, chroma resampler, color space converter and scaler megacore function between two avalon streaming interfaces as it is shown in the figure.
I want to process video data packets only, so I have to import a custom logic block(vhdl or verilog file) in between deinterlacer and chroma resampler, but the problem is I donot know before the video packets either the control packets are coming or not.
How Custom logic block(vhdl or verilog file) can differentiate between video and control packets??????
I donot know how to handle this issue of control packets!!!!!!!!
If you have any idea please let me know.
Thank You
AoA Rizwan sb
I am Rafi from Lahore Pakistan. I can not any help for you. Because i am a biggner in FPGA.
If you can my help? please tell me about Quartus II, SOPC Builder and Nios II Eclipse Plateform.
When i press the button "submit reply" then occure error message
"please remove e-mail addresses from your message, then you will be able to submit your post.
my email address is "srafi56 at the rate of yahoo dot com"
Thank you
Rafi
