FPGA Intellectual Property
6673 Discussions
develop device driver for HAL
hi,
I have a problem looking for help.
I planned to develop device driver for my custom IP core.
Altera supply some drivers for generic device,such as UART,JTAG UART .These drivers usually contain *_regs.h,*.h and *.c.
when i create a BSP project by niosII SBT for Eclipse,if my hardware file (*.sopcinfo) contain UARTcomponent,the driver for UARTcan be copied to
my BSP project directory automaticlly,then my BSP driver folder contain
altera_avalon_uart_regs.h,altera_avalon_uart.h and altera_avalon_uart.c.
the problem is as follows:
after my custom IP core driver has been developed,when i create a BSP project by niosII SBT for Eclipse,the driver files (*_regs.h,*.h and *.c)cannnot be copied into the BSP driver folder as the UART files(altera_avalon_uart_regs.h,altera_avalon_uart.h and altera_avalon_uart.c).
thanks for help!
You need to put a list of your source files in a tcl file with your component. Have a look at this document (http://www.altera.com/literature/hb/nios2/n2sw_nii52005.pdf).
