FPGA Intellectual Property
dft problem
greetings,
hi i have typed followin code to verify samplng theorem but the answer is coming something different.may i know the reason.
clc;
fs=800;
t=0:1/fs:1
x=cos(2*pi*400*t);
xm=(fft(x));
k=0:length(xm)-1;
subplot(2,2,1);
stem(k,xm)
xlabel('hertz')
ylabel('magnitude')
title('sampling')
the result should come at only one frequency(i.e one line at frequency of cosine) as the signal is cosine but spectrum is continious. why ?
the spectrum (o/p)is attached here
thanks in advance
You're doing:
t=0:1/fs:1
x=cos(2*pi*400*t);
The step is 1/fs, which is 1/800 = 0.00125
This means, that from range 0 to 1, every 0.00125 step You'll get a new frequency (because argument 't' in cosine function is changing), that is: 800 results. So what do You expect in frequency domain to see?
your frequency is half sampling rate and is one line mirrored
plot(k,abs(xm));
--- Quote Start ---
You're doing:
t=0:1/fs:1
x=cos(2*pi*400*t);
--- Quote End ---
but my signal is cosine and the sampling rate is also twice of highest frequency ,so corresponding i must gate only two frequency component.
But I told you you have got it. Just your plot is wrong.
