FPGA Intellectual Property
6670 Discussions
erro when compiler DSP Builder Advance Blockset
Pls help me!
When I compiler my model in DSP Builder Advance Blockset, I receiver erro "Hardware Generation Disable Failed to obtain a valid license please ensure that you license file is on you Matlab Path ,or contact Altera to obtain a license Simulation will continue for evaluation purposes"
When I run "ver": Altera DSP Builder Advanced Blockset Flow Tools Version 0.0.0 (Release)
do you own a license for DSP Builder and is it on your LM_LICENSE_FILE environment variable?
Yes, it is on my LM_LICENSE_FILE environment variable
--- Quote Start ---
--- Quote End ---
the license maintenance date must be older than the DSP Builder version you are using
