FPGA Intellectual Property
6673 Discussions
error when parametrizing fft megacore
When I try to parametrize the fft megacore v8 to check if dsp builder is working I get this error message in the command prompt:
Error in block : untitled/fft_v8_0
Java exception occurred:
java.lang.UnsatisfiedLinkError: com.altera.dspbuilder.simulation.Block.rename(Ljava/lang/StringV
at com.altera.dspbuilder.simulation.Block.rename(Native Method)
at com.altera.dspbuilder.simulation.Block.setName(Unknown Source)
at com.altera.dspbuilder.simulation.Mask.init(Unknown Source)
Can anyone help me?
8.0 is getting to be pretty old (and unsupported). can you use a newer version of the tool?
I'm working only with quartus II v8 & dsp builder v8 so I can't use any other version
