FPGA Intellectual Property
6670 Discussions
frame reader configuration and initialization
I use the frame reader in my design with the following settings:
Bits per pixel per color plane: 8
Number of color planes in parallel: 3
Number of color planes in sequence: 1
Maximum Image width: 1920
Maximum Image height: 1080
Master port width: 64
Read master FIFO depth: 1024
Read master FIFO burst target: 64
Use separate clock for the Avalon MM master interface: unchecked
Kindly confirm if the following calculations for number the words and the Single Cycle Color Patterns are true or not
1- // Words
IOWR(FRAMEREADER_BASE, 5, 259200); // (1920*1080*8*3)/48= 1036800
2- // Single Cycle Color Patterns
IOWR(FRAMEREADER_BASE, 6, 2073600); // 1920*1080=2073600 number of pixels in the frame multiplied by the number of single cycles required to represent one pixel
Your reply will be highly appreciated
