FPGA Intellectual Property
help:DDR2 problem
Hi, I met a strange problem about DDR2 controller. I use the DDR2 SDRAM Controller v9.1. Sometimes the local_rdata has a value a cycle early before the local_rdata_valid is high and the following values are not what I have written into the ddr2 when local_rdata_valid is high. How can I solve this problem? Thank you very much.
