the steps of my signal processing is as follows:
Analog data ->ADC ->FIFO ->FFT the ADC sample rate is 200Msps, I want to implement FFT in the cyclone ii FPGA with the FFT IP core, I want the clock of the FPGA is 100MHz, so how can i process the 200Msps data in 100MHz of clock rate and what is the function of the FIFO, is it should be implement inside the FPGA or with a FIFO chip? I'm very puzzled about it.Link Copied
