FPGA Intellectual Property
6670 Discussions
how can Arria10 10GE MAC send the long packet ?
JET60200
hello,  we rae using Ariia10 LL10GE MAC IP, and we need send a long packet with length of "17536 bytes".
to my understading, 10GE MAC can only send 1500 bytes as longest by default,  so how to config 10GE MAC to make it sending  "17536" long packet for us ?
Please help & thanks
Deshi_Intel
I noticed there is one register control called "tx_frame_maxlength" (0x002C) as shown in user guide doc page 77.
You can try change this register value from default 1518 setting to some other setting
dlim
Deshi_Intel
Sorry, I take back my words.
I cross check with Ethernet frame spec as in IEEE 802.3.
dlim
JET60200
hi @Deshi_Intel ,
you said "1500 is the max frame length" for 10GE, right ?   but I see in some document, MTU=9600 is also supported by intel A10 FPGA, how could it reach that (I mean MTU=9600 bytes ) ?
Pls double check from your intel inside.  Thanks
Deshi_Intel
HI,
9600 is referring to jumbo packet. Standard packet still only support 1500.
As the Max Tx/Rx frame length bit are 16 bits register, so you should be able to still set it to 9600 but you need to take care of external FIFO depth size to be able to support this large data transfer.
I found out below KDB link that mentioned about the risk in transferring large packet size
dlim
Deshi_Intel
I hope I have answered your doubt.
I am now setting this case to closure.
dlim
