FPGA Intellectual Property
6670 Discussions
how to calculate the length register and the burst count port in DMA control manual
hello:
when I read the DMA control manual provided by the altera.com,I came across a question.
According to the manual at page 3 "The master Read and Write port",it says "For example, if a 32-bit data width DMA is programmed for a word transfer of 64 bytes, the length registered is programmed with 64 and the burst count port will be 16. If a 64-bit data width DMA is programmed for a doubleword transfer of 8 bytes, the length register is programmed with 8 and the burst count port will be 1."
I can't understand the meaning of the above paragraph,can anyone help me?
Length register == number of bytes.
Burst count == number of transfers of full bus width.
64 bytes (512 bits) on 32 bit bus: 512/32 = burst count of 16.
8 byte (64 bits) on 64 bit bus: 64/64 = burst count of 1.
--- Quote Start ---
--- Quote End ---
Matthias Wachter:
thank you very much,best wishes!
