hello everybody:
when I open the nios , and want to set a new c/c++ application , the template column is empty , I dont know how to solve the problem . if somebody know . tell me thanks a million. :)链接已复制
3 回复数
Maybe you didn't select "New NIOS C/C++ application" in the menu because you don't have it because you don't work in the "nios perpective".
Select this at the bottom left on nios II IDE. Sorry for my english. ++thank you first , but I can not find the "nios perpective" item in the left bottom of nios ide. my version is 7.1, may there be some difference with your version??
waiting for your message again. thanks in advance:)
