FPGA Intellectual Property
importing hex files
Can I import hex files from quartus project with HDL import block?
As far as I know, the only option to import hex files is for ROM/RAM initialization.
Can you explain more. I'm a beginner with dsp builder
For what do you want the .hex files ?
Is it a processor executable ?
FPGA bitstream ?
RAM initialization ?
ROM initialization ?
State machine encoding ?
One more question: by hex, do you mean a file in Intel HEX format or just a text file with hexadecimal data?
Hi everyone,
I have a quartus project including fft megacore and some other vhdl files.
I want to import all the project to simulink;
when I do this with HDL Import bloc, I got many warnings like this one:
Could not find RAM initialization file 'fft_opt_twr1.hex'
What can I do to avoid these warnings
Put the .hex files in the same directory as the other files.
Or simply correct the path so that it points to the correct place.
Problem solved.:)
Thank you
