FPGA Intellectual Property
6670 Discussions
intel early pin assignment
SERMASWATHIKA
i have tried to generate pin report for dummy design as whole design completion takes time. when i tried to assign epcs pins to design pins, it is not accepting and showing error as dedicated pins can not be assigned. but epcs pins only got assigned for that error is showing for cyclone v gx.
is there any rule like epcs controller ip instantiation is required to assign the dedicated pins?
as early pin check, i didnt add any actual ip interface, just i have created the topfile with input , output
Please help me to solve this?
sstrell
Can you show the actual errors, code, etc.?  Hard to figure this out without any details.
SERMASWATHIKA
attached the error message .
sstrell
Can you expand the error messages to show the actual details?  This doesn't help much.
SERMASWATHIKA
attached the expand error message with this
sstrell
Clearly, you can't use AF5 for this function since it's a dedicated programming pin.
SERMASWATHIKA
but i am assigning epcs controller pins only. Whether this dedicated pin will automatically assign once we instantiate the epcs controller ip.
Fakhrul
Hi SERMASWATHIKA,
Based on my understanding you won't need to assign the pin manually, dedicated pins are typically assigned through the pin planner or assignment files in the Quartus. May I know specifically what are you trying to achieve?
Fakhrul
Fakhrul
Please be advised that due to the absence of a response from you regarding the previous notification we provided, we will be transitioning this thread to community support. If you have any new questions or concerns, we kindly suggest opening a new thread to receive assistance from Intel experts. However, if you do not have any further inquiries, the community users will be available to assist you on this thread. Thank you for your understanding.
