FPGA Intellectual Property
6673 Discussions
intel fft ip fixed point with fractional bits
AlexBeasley
Hi there,
I am using the Intel (altera) FFT IP core and I have it configured in fixed-point variable streaming mode. Which lets me set the "data width".
My data is in a fixed point format but it has both decimal and fractional bits (m.n) format. However, I can not see anywhere in the documentation to tell me if fixed-point mode supports data with fractional bits. Can you clarify on this please?
Kshitij_Intel
Sharing the documentation. Please go through it.
https://www.intel.com/content/www/us/en/docs/programmable/683374/17-1/variable-streaming-fft.html
https://www.intel.com/content/www/us/en/docs/programmable/683374/17-1/fixed-point-variable-streaming-ffts.html
If you still do not find the answer you are looking then please elaborate your question.
Thank you
Kshitij Goel
AlexBeasley
My understanding from the documentation (and using the IP core), is that fixed-point mode is for 2's complement integer data only. Is this true? I really wanted 2's complement fractional data.
Many thanks
Kshitij_Intel
Let's say for m.n eg. 5.11 and your input is 16bits and you are performing 4096 points FFT the output will be 16 bits +13bits = 29bits you should be able to see the output as 18.11.
Thank you
Kshitij Goel
Kshitij_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you
Kshitij Goel
