FPGA Intellectual Property
6670 Discussions
programming problem with new Generic Serial Flash Interface Intel FPGA IP Core.
DReme
I have a board with Cyclone V and Micron QSPI FLASH MT25QL01G.
I use Quartus 18.1.
This is additional data FLASH device on my board not for FPGA configuration. I use a new Generic Serial Flash Interface Intel FPGA IP Core that is configured for 1024 Mbits devices and not AS mode.
I am able to read and initialize the device but can not program it. Has anyone already done this?
Dmitry
Nooraini_Y_Intel
Hi DReme,
Are you using the reference design from the Generic Serial Flash Interface Intel FPGA IP Core User Guide? Or are you building your own design using the IP to access the MT25QL01G? Please provide more details on the steps you did when using the IP and failure symptom (error message or IP signal not behaving as expected). As far I know, the published reference design was validated by the internal team working correctly.
https://fpgacloud.intel.com/devstore/platform/2179/
Nooraini
