FPGA Intellectual Property
6669 Discussions
"Boards" installation error
Hi all,
I'm currently using MATLAB 7.9.0 (r2009b) and quartus 9.1 web edition. I installed "DSP builder 10.0" but when i explored the installed components in simulink, i couldn't see the boards section under the "Altera DSP Builder Blockset". I uninstalled the DSP builder and tried to install it back. While installation matlab command window opens for a short time and there writes some error message as seen in the below figure.(attachments)
Can you please help me, then i can install the boards and use the specific one(de2-70) in my simulink model.
Thank you
you should try installing the same version of QII and DSP Builder
Thank you "thepancake", i tried to setup quartus 10.0 with the help of altera installer but it gives me errors. i will install quartus 9.1 back but i couldn't find DSP Builder 9.1 now. Can anyone please help me where to find DSP Builder 9.1 version.
thank you very much :)
