FPGA Intellectual Property
6673 Discussions
"*.hexout" file changing on every compilation. How to avoid it?
Hi All,
I am using quartus 9.1 350 build (32 bit version) , I am compiling a design, after every compilation "*.hexout" file generated is changing as compared to previous "*.hexout" file.
Kindly let me know, what settings in the tool I need to change to generate same "*.hexout" file irrespective of number of compilation.
Note : I did not change anything in the design ,I am just compiling same design multiple times.
Please take your valuable time in replying to the thread.
Thanks in advance.
You can try to refer to this solution link for some information:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05272011_80.html
