Hi All,
is there any possibility to use parameter selecation in place of `ifdef and `else Your timely response is very appreciated! Regards DivyeshLink Copied
If you really want a timely response, you'll have to give more details. What language are you using, what parameters are you talking about and what do you want to do with them?
ok i apologies for that.
i am using verilog. my problem is that i want to instantiate one module more than one time using keyword perameter instead of ifdef. e.g. `define EP1_ENABLE 1 `define EP2_ENABLE 1 . . . module test(); . . . . . // instance of other module `ifdef EP1_ENABLE ep_register `else ep_register_dummy `endif `ifdef EP2_ENABLE ep_register u2( .(), ); `else ep_register_dummy u2( .(), ); `endif endmodule this implementations is using ifdef, we want same implementations using PARAMETER so please let me know if there is any way- Mark as New
You may want to consult your favourite Verilog text book or reference manual for the purpose of generate statement.
thanks for reply...
i got the solution for my problem. In that as per perameter selection value implemented on hardware. thanks again
