FPGA Intellectual Property
6670 Diskussionen
strange CRA register map in PCIe ref design based on SOPC flow
Geehrter Beitragender II
1.405Aufrufe
Hi every one
I use PCIe soft IP based on the sopc flow. I obversed that in the testbench altpcietb_bfm_driver.v the DMA CRA register map are strange.
To access DMA read addr register,write addr register ,length register and control register,the testbench write addr are CRA base + 0x08, CRA base + 0x10,CRA base + 0x18,CRA base+ 0x30.
The CRA access is through bar 2 which is 32 bit non-prefetch bar. Why the write addresses are not CRA base + 0x04, CRA base + 0x08,CRA base + 0x0C,CRA base + 0x18?
4 Antworten
693Aufrufe
Because of the 64 bit length of the BAR interface.
693Aufrufe
Thanks for reply.
My avalon-MM custom component's control interface is 32bit width(the readdata and writedata signals are 32 bit).
I connect the component's control interface with BAR 2 and want to access register in the control interface from root complex. Should the address increase with regOFFSET *8 ? or regOFFSET *4 ?
693Aufrufe
If you do a 64-bit write at address 0 of BAR0, will be done 2 writes at offsets 0 and 1. It's possible to do a 32-bit write, so, will be done one write at respective offset.
This question is a little confused to understand. Take a look on the section Address Alignment of chapter Avalon Memory-Mapped Interfaces of the document Avalon Interface Specifications to try understand this question.
I recommend to look the signals with a signaltap module, and try to understand the address alignment.
693Aufrufe
--- Quote Start ---
--- Quote End ---
Thanks for help.
Thourgh the pcie user guide give a sopc based example,it does not say that the 64 bit prefetch BAR 1:0 and 32 bit pretch Bar 2 are 64 bit interface explicitly. I found that when i generated the sopc system the builder give a warning stated that 64 bit prefetch BAR 1:0 only support 64 bit memory.
To connect my 32 bit custom component control interface to Bar 2, as you say,64 bit write to Bar 2 will be done 2 writes.So I recoded the 32 bit registers with address (byte offset) 0x0,0x8,010,.... It works correctly.
Thanks again.
Antworten
