FPGA Intellectual Property
6669 Discussions
the Marvell phy supported in the LL 10G testing script file
XXiao2
I am trying to test the LL 10G with a 10GBASE-T adapter which is connected to a CAT 6 cable. does the script file coming with the project support that? the part number of Marvell PHY is 88X3310
CheePin_C_Intel
As I understand it, you have some inquiries related to our IP interfacing with a 3rd party PHY. Sorry for any confusion, just would like to check with you on the following:
  1. Mind let me know the specific LL 10G IP that you are using? Some reference to web or documentation would be helpful.
  2. Just would like to check with you which Quartus version and device that you are using with the IP?
  3. Are you using Intel devkit or your custom board?
  4. Just wonder if you are using any reference design from Intel? If yes, would you mind to help referring me to it ie download link.
Thank you.
CheePin_C_Intel
Just would like to follow up with you on this. Please let me know if there is any concern. Thank you.
Chee Pin
