FPGA Intellectual Property
6670 Discussions
unable to compile libraries for emif IP in quartus 19.3 in cadence.
DChak3
I tried to compile libraries for EMIF IP generated from quartus 19.3 version device used stratix10. While running the command ncsim_setup.sh. It stoped follwing the error attached.
Deshi_Intel
Can you help to clarify further on your problem statement ?
  1. Which ncsim version that you used ? Byright Quartus v19.3 should pair with ncsim version 15.20.074
  2. Are you running the sim using EMIF example design ?
  3. If yes, which EMIF protocol that you used and what's the DQ width ?
Once you clarified on the info then I can try run the sim from my side to see whether I can duplicate your issue or not
dlim
