FPGA Intellectual Property
6670 Discussions
why the on-chip dual clock ram has no read signal?
I add a on-chip dual clock ram with on-chip memory?
but it has no read signal for two port,why?
and how to read the ram with this circumstance?
??write high for write,and low for read?
thank!
imagine that when you write data into sram.
you specify the address, but in some case you don't want write data.
therefore you need write_enable signal.
how about read sequence?
read data appear as you specify address.
if you don't want to use the data?
just ignore it.
that is why you don't need read_enable signal.
Are you generating this onchip memory for NIOS II as
in normal IP generation case i feel it rd_enable will be there
but in Nios II situation we use IORD_32direct and read enable will not be available for user to control
thanks all!
I use this dpram for nios2 and my logic.on port for nios2 and another for my logic.
so I want to known how to access the dpram for my logic without read signal.
i think akira is right.
I will test it !
