6460 Discussions
ARRIA 10: The impedance between VCC and GND is only 2Ω
WKUAN
Folks, I just finished the soldering of Arria10 10AX115NF45 chip. After the soldering , I measured the impedance between VCC and GND and found that it was only 2 ohm, between VCCA_PLL and GND was only 20 ohm. Is this normal?At present, the PCB has not been powered on.
EngWei_O_Intel
Hi Wu Kuang
We do not have specification for this. May I know your concern of this?
Eng Wei
WKUAN
Dear Eng Wei
Thanks for your reply, I want to know if the impedance between VCC(0.9V) and GND is too low (2ohm)?  Is it damaged or  still nomal?  I have to make sure the chip is ok before power the board up.
Thanks and best regards,
KUANG Wu
EngWei_O_Intel
Hi Kuang Wu
We don't have data on this so I am not able to confirm on this. What is the expected measurement? Are you trying to identify whether they are short circuit?
Eng Wei
WKUAN
Hi Eng Wei,
Yes, I am trying to identify whether they are short circuit
KUANG Wu
WKUAN
Hello all, I have powered the board on, it is ok, the 2Ω impedance between VCC and GND is nomal.
EngWei_O_Intel
I’m glad that you have your issue resolved, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
WKUAN
