6472 ディスカッション
Building uboot for cyclone V SoC
snehal_p
新規コントリビューター I
5,305件の閲覧回数
We want to build boot image for customized cyclone V SoC board.
We are following the below document, using Quartus Prime 22.1 Standard Edition on Ubuntu 20.04 system,
We are getting below error while building uboot
/usr/bin/ld: tools/imagetool.o: in function `imagetool_get_type':
imagetool.c:(.text+0xa): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x12): undefined reference to `__start_image_type'
/usr/bin/ld: tools/imagetool.o: in function `imagetool_verify_print_header':
imagetool.c:(.text+0x73): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x7a): undefined reference to `__start_image_type'
collect2: error: ld returned 1 exit status
make[1]: *** [scripts/Makefile.host:104: tools/dumpimage] Error 1
make: *** [Makefile:1900: tools] Error 2
Can you please share your insights.
snehal_p
ラベル(1)
0 件の賞賛
1 解決策
JingyangTeh_Altera
従業員
2,951件の閲覧回数
Hi Snehal
Just to update the forum case.
The missing steps from the RBO page are the steps below:
1.Step to convert the sof to rbf. You could use the command below to convert the sof.
quartus_cpf -c -o bitstream_compression=on soc_system.sof soc_system.rbf
2.Missing u-boot.scr could be gotten from the gsrd page.
https://releases.rocketboards.org/2025.03/gsrd/c5_gsrd/u-boot.scr
3.Place both rbf and the u-boot.scr in the sdcard partition 1 (sdfs)
Jingyang, Teh
元の投稿で解決策を見る
31 返答(返信)
JingyangTeh_Altera
従業員
4,170件の閲覧回数
Hi
Sorry for the late reply.
If you are using the latest in the repo, there might be some bugs that was recently uploaded.
In the uboot repository, could checkout the branch "git checkout -b test-bootloader -t origin/socfpga_v2024.04" .
Jingyang, Teh
snehal_p
新規コントリビューター I
4,152件の閲覧回数
Hello JingyangTeh,
Thanks for the response.
Please check the steps below,
1) git clone https://github.com/altera-opensource/u-boot-socfpga
2) git checkout -b test-bootloader -t origin/socfpga_v2022.10
3) cd arch/arm/mach-socfpga/cv_bsp_generator/
4) python cv_bsp_generator.py -i path/hps_isw_handoff/soc_system_hps_0 -o ~/software/bootloader/u-boot-socfpga/board/altera/cyclone5-socdk/qts
5) cd arch/arm/mach-socfpga/cv_bsp_generator/
6) export CROSS_COMPILE=~/software/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf-
7) make socfpga_cyclone5_defconfig
make -j 48
Error message:
./tools/mkimage: unsupported type Altera SoCFPGA CV/AV preloader
make[1]: *** [scripts/Makefile.spl:426: spl/u-boot-spl.sfp] Error 1
make: *** [Makefile:2081: spl/u-boot-spl] Error 2
make: *** Deleting file 'spl/u-boot-spl'
snehal_p
snehal_p
新規コントリビューター I
3,998件の閲覧回数
Hello JingyangTeh,
Please PFA error message
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Appendix_45_Building_Linux_Binaries
this document is suggesting to use uboot branch 2022.04, but I'm getting below error.
Can you please help with the issue.
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [scripts/Makefile.host:104: tools/mkimage] Error 1
make[1]: *** [scripts/Makefile.host:104: tools/fit_info] Error 1
make[1]: *** [scripts/Makefile.host:104: tools/fit_check_sign] Error 1
snehal_p
TruHy
ビギナー
4,145件の閲覧回数
I think there is a missing parameter, try adding this before or after step 6:
export ARCH=arm
snehal_p
新規コントリビューター I
4,138件の閲覧回数
Hello TruHy,
Tried adding
export ARCH=arm
but still getting same error
snehal_p
JingyangTeh_Altera
従業員
3,973件の閲覧回数
Hi
I tried the steps and able to build uboot successfully.
Could you try setting :
export CROSS_COMPILE=arm-none-linux-gnueabihf-
Also check the path for the compiler to be set properly:
wget https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
tar xf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
rm gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
Further more the cv_bsp_generator.pt needs to run using python2 instead of python3
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH
Jingyang, Teh
snehal_p
新規コントリビューター I
3,958件の閲覧回数
Hello JingyangTeh,
I tried the steps but still gtting error. PFA.
snehal_p
snehal_p
新規コントリビューター I
3,927件の閲覧回数
Hello JingyangTeh,
I'm using Ubuntu 20.04 linux system, can you share which linux environment you tried building uboot
snehal_p
JingyangTeh_Altera
従業員
3,911件の閲覧回数
Hi
Could you try installing some pre-requisite packages below:
sudo apt-get install gawk wget git-core diffstat unzip texinfo \
gcc-multilib build-essential chrpath socat cpio python python3 \
python3-pip python3-pexpect xz-utils debianutils iputils-ping \
python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev pylint3 xterm \
libncurses-dev gawk flex bison openssl libssl-dev
If not could you try building it in Ubuntu 22.04 with the packages above too.
Jingyang, Teh
snehal_p
新規コントリビューター I
3,890件の閲覧回数
Hello JingyangTeh,
PFA error received and details of issues received for both Ubuntu 20.04 and Ubuntu 22.04.
Building it in Ubuntu 22.04is successful, but zImage and Rootfs build is getting issue.
snehal_p
新規コントリビューター I
3,875件の閲覧回数
PFA steps and terminal log on Ubuntu 20.04
snehal_p
JingyangTeh_Altera
従業員
3,534件の閲覧回数
Hi
Sorry for the late reply, I was OOO last week.
Have you installed the packages in my previous comment in your environment?
I tried building the steps but did not observe the error you are facing.
Jingyang, Teh
snehal_p
新規コントリビューター I
3,504件の閲覧回数
Tried on another ubuntu 20.04 system, the build is successful. But on my system I still get the error even after installing the packages you have suggested.
Any suggesstions
snehal_p
JingyangTeh_Altera
従業員
3,456件の閲覧回数
Hi
Could you also try these packages:
sudo apt install make
sudo apt install gcc
sudo apt install binutils-doc gcc-multilib autoconf automake libtool flex bison gcc-doc gcc-11-multilib gcc-11-doc gcc-11-locales
sudo apt install ncurses
sudo apt install ncurses-compat-libs
sudo apt-get install gcc-arm-linux-gnueabihf
Jingyang, Teh
snehal_p
新規コントリビューター I
3,420件の閲覧回数
I tried but same error.
I tried booting using files generated on another system, getting attached error, can you please help.
JingyangTeh_Altera
従業員
3,335件の閲覧回数
Hi
The ddr in the hardware you are using is having a 512MB DDR as where the GSRD for the devkit is having 1GB.
Please change the device tree arch/arm/dts/socfpga_cyclone5_socdk.dts to
memory {
name = "memory";
device_type = "memory";
reg = <0x0 0x20000000>; /* 1GB */
Jingyang, Teh
snehal_p
新規コントリビューター I
3,314件の閲覧回数
Did try this but still getting error, PFA dts file
snehal_p
JingyangTeh_Altera
従業員
3,203件の閲覧回数
Hi
The changes looks good in the device tree.
What is the new error message that you are getting?
Did the logs show the DDR size define in the device tree size to be 512MB?
Jingyang, Teh
snehal_p
新規コントリビューター I
3,176件の閲覧回数
1) PFA debug log images,
Image_1 is when baud in 115200 uboot boot log is visible but as soon as it goes to kernel config then it shows garbage data,
if  baud changed  to 230400 then uboot boot log is not visible garbage data but kernel boot log can be seen after that all system runs on 230400 baud even able to run the application.
2) PFA debug log, we have enabled emac 0 hps peripheral in fpga mode. But ethernet is not being detected. Is it because we are using dtb file generated by the steps mentioned in the below document. Do we need to generate dtb by some other steps, if yes please share the steps.
snehal_p
snehal_p
新規コントリビューター I
3,107件の閲覧回数
Can you help with command to generate dts with sopcinfo and board xml files as input.
The below command works in SOC EDS, which is discontinued in Quartus 22.1
sopc2dts --input soc_system.sopcinfo\
--output soc_system.dts\
--type dts\
--board soc_system_board_info.xml\
--board hps_common_board_info.xml\
--bridge-removal all\
--clocks
snehal_p
返信
