I can't get the drivers to install on a windows 20h2 installation. I have tried DPINST.exe, bblpt, and manual through the control panel pointing to the driver. Does anyone have any ideas. I have disabled UAC as well...
DPINST just says an error occured.
bblpt says it cannot start the service.
and control panel says a problem was encountered while attempting to add the driver to the store.
Thank you for contacting Intel community.
That might be due to issue with USB Blaster II. Kindly follow the workaround in KDB below (it is also applicable for USB Blaster):
Aiman
Aiman
That worked... Thanks you very much...
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
