6468 Discussions
COMBINE ELF FILE INTO SOF FILE
vietvu1912
I have some problems when I try to combine elf file into sof file.
1, I use "sof2flash" but I get a message that: "unrecognized device family in SOF". Does this command "sof2flash"  not support for Cyclone  10GX?
2, when I use "elf2flash" and "nios2-elf-objcopy", I generate a hex file from elf file. I try to use Convert Programing File in Quartus Pro and generate a jic file. I loaded that file into the Cyclone 10GX kit with EPCQL1024. But, it doesn't work like when I load and run sof file and elf file. I think it work like when I load sof file. elf file after combine into sof file doesn't work.
3, I try to load pof file into the Cyclone 10GX with EPCQL1024, but I receive the message cannot add target device EPCQL1024 to device chain when in current programming mode. I tried to use active serial programming and JTAG but it doesnt work.
Can anyone tell me how to solve this problem? Thank you so much.
best regard,
Viet
NurAiman_M_Intel
Thank you for contacting Intel community.
What is the Quartus version that was used? I would recommend to used the latest version.
Due to a problem in the Intel® Quartus® Prime Design Software version 17.1 and earlier, the sof2flash utility may fail to work with EPCQ device in Intel® Arria® 10, Intel® Cyclone® 10 and Intel® Stratix® 10 designs. You can also view the workaround/Fix from our KDB below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/why-does-the-sof2flash-utility-fail-to-work-with-intel--arria--1.html
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
vietvu1912
Thanks for your support. This problem has solved. But I have new problem when I try to run C file in fpga Nios II. I receive a error message: "Connected system ID hash not found on target at expected base address". I search to solve this problem, and I have added "System IP Peripherial" IPcore, but this problem can't solve. Can you support me to solve this? Thanks.
my project has attached below:
