6472 Discussions
Flash Loader IP not loaded on device 1?
FN0001
I have a Cyclone IV based FPGA board (LimeSDR-PCIe v1.3) I am trying to flash FPGA FW but in Quartus I always get this error. "Flash loader IP not loaded on device 1" see log below.
/altera_lite/15.1/quartus/bin$ quartus_pgm -m jtag -o "ipv;./LimeSDR-PCIE_lms7_trx_HW_1.3.jic"
Info: *******************************************************************
Info: Running Quartus Prime Programmer
  Info: Version 15.1.2 Build 193 02/01/2016 SJ Lite Edition
  Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved.
  Info: Your use of Altera Corporation's design tools, logic functions
  Info: and other software and tools, and its AMPP partner logic
  Info: functions, and any output files from any of the foregoing
  Info: (including device programming or simulation files), and any
  Info: associated documentation or information are expressly subject
  Info: to the terms and conditions of the Altera Program License
  Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
  Info: the Altera MegaCore Function License Agreement, or other
  Info: applicable license agreement, including, without limitation,
  Info: that your use is for the sole purpose of programming logic
  Info: devices manufactured by Altera and sold by Altera or its
  Info: authorized distributors. Please refer to the applicable
  Info: agreement for further details.
  Info: Processing started: Wed Apr 22 13:06:06 2020
Info: Command: quartus_pgm -m jtag -o ipv;./LimeSDR-PCIE_lms7_trx_HW_1.3.jic
Info (213045): Using programming cable "USB-Blaster [1-2]"
Info (213011): Using programming file ./LimeSDR-PCIE_lms7_trx_HW_1.3.jic with checksum 0x7273C3BF for device EP4CGX30CF23@1
Info (209060): Started Programmer operation at Wed Apr 22 13:06:07 2020
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x028230DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Error (209062): Flash Loader IP not loaded on device 1
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Apr 22 13:06:11 2020
Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings
  Error: Peak virtual memory: 411 megabytes
  Error: Processing ended: Wed Apr 22 13:06:11 2020
  Error: Elapsed time: 00:00:05
  Error: Total CPU time (on all processors): 00:00:01
Can anyone guide me what the issue could be, Is there some file missing?
The repo is available here: https://github.com/myriadrf/LimeSDR-PCIe_GW
I am using Quartus Lite 15.1.2 Build 193.
NurAiman_M_Intel
Thank you for contacting Intel community.
You can try to use following solution:
  1. https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd01102012_443.html
2. ID:209062 Flash Loader IP not loaded on device <number>
CAUSE: You tried to program one or more serial or parallel configuration devices, using a Programmer Object File (.pof) (../../reference/glossary/def_pof.htm). However, the specified device was not configured with the Flash Loader IP.
ACTION: Make sure the Flash Loader IP is loaded on the device, and make sure the POF can communicate with the device, for example, make sure the communications cable is properly attached and the device has power.
Let me know if you need further information.
Thank you.
Aiman
FN0001
Hi Aiman,
Thank you for your reply. Itrei I have two such development boards and the issue always happens on one of those and occasionally on the other. I do the following steps for programming.
  1. Open programmer in Quartus.
  2. Select USB-Blaster in Hardware tab
  3. Select Auto Detect.
  4. Select change file and choose the corresponding myfile.jic
  5. New design opens up. I check both boxes on Program/Configure (For FPGA and EPCS64 flash).
  6. Click on Start.
  7. The procedure halts at 21% with the message "Flash loader IP not loaded on device 1"
With the above procedure after checking the Program/configure box a Factory default SFL file is selected to be loaded. Is there any other extra step I should do?
Following are the screen shots.
NurAiman_M_Intel
Have you tried with USB Blaster II?
Thank you.
Aiman
NurAiman_M_Intel
Is there any update on this request? Else, I will continue to close this case
Thank you.
Aiman
WFitt
I have the same problem with programming Cyclone 10 (10CL025Y).
I try to program a JIC file via Altera USB-Blaster. The error message "Flash Loader IP not loaded on device 1" appears. The SOF file is getting programmed well.
I generated the JIC-File with the Quartus tool "Converting Programming Files".
Has anyone an idea?
Wolfram
MarcoWu
Please try to change the code of FPGA to the same JIC file. Then you can program the flash without problem.
WFitt
Hi MarcoWu,
Thank you for your hint!
But I solved the problem yet: The FPGA was held in reset. An other error message like "FPGA in reset, no access possible" would have been very helpful ;-).
