6459 Discussions
CPU is not recognized while creation of bsp
Ranjani
Hi all,
 I want to design simple code like hello.c on ARRIA 10 evaluation board. for this i would like to use IBEX as CPU instead of Nios. While I try to export the bsp settings to Ashling IDE,  qsys is not able to figure out the cpu from drop down. Any workaround from anyone will be appreciated.
I have attached the snip for your reference.
Thanks in advance folks.
sstrell
I seriously doubt this is supported unless you've found information that proves otherwise.
Ranjani
Hi SStrell
Thanks for your message. I see some examples done on other FPGA's , but on quartus I didn;t find any
