6472 Discussions
Calibration failure for DDR4 EMIF in arria 10 SoC development kit
srinivasan
I am getting calibration failure for DDR4 EMIF in arria 10 SoC development kit..
What is the reason for getting failure?
Can anyone give solution for error?
yoichiK_intel
Hi
Probably the pin location or memory parameter's are mistaken.
Please take an advantage of using the preset of targeting Arria10 SoC devkit for DDR4 EMIF example design.  This will generate 100% guaranteed functional design.  Please follow the link for the detail.
https://www.intel.com/content/www/us/en/programmable/documentation/pvu1502901260167.html#mhi1440164255731
srinivasan
Eventhough I am selecting the same the arria 10 SoC development kit from preset...but I am getting the calibration failure..
If so possible ,can u please share your EMIF traffic gen working project...
yoichiK_intel
Hi
Which of FGPA EMIF or HPS EMIF are you referring to ?
srinivasan
Fpga EMIF for arria 10 SoC development kit
yoichiK_intel
please try to use the attached design.  the design was created by Quartus pro 20.4 version.
srinivasan
Can you able share .zip file..beacaue war file it is not opening..
srinivasan
Whether your project created in quartus prime pro 17.1...because 20.4 lite edition no arria 10 available..only in standard edition only available...so I dnt have liscence for that...could u able share 17.1version project file..
yoichiK_intel
Hi
Here is the design for 17.1 pro and zipped for you.
srinivasan
Thanks for sharing...
But I got output for that...
If u have created user interface( Avalon-mm) for EMIF IP..if so possible can u share the file?
yoichiK_intel
Hi
The traffic generator module is attached in the design  which interfacing to DDR4 EMIF IP via Avalon-mm.
the module path is here
qii/ip/ed_synth/ed_synth_tg/synth/ed_synth_tg.v
srinivasan
Ya correct...I am asking user interface vhdl code(Avalon mm) to interface with EMIF IP
Need to remove tg and include user interface code..
