連結已複製
11 回應
Hi
Probably the pin location or memory parameter's are mistaken.
Please take an advantage of using the preset of targeting Arria10 SoC devkit for DDR4 EMIF example design. This will generate 100% guaranteed functional design. Please follow the link for the detail.
- 標籤:
- o
Eventhough I am selecting the same the arria 10 SoC development kit from preset...but I am getting the calibration failure..
If so possible ,can u please share your EMIF traffic gen working project...
please try to use the attached design. the design was created by Quartus pro 20.4 version.
Can you able share .zip file..beacaue war file it is not opening..
Whether your project created in quartus prime pro 17.1...because 20.4 lite edition no arria 10 available..only in standard edition only available...so I dnt have liscence for that...could u able share 17.1version project file..
Thanks for sharing...
But I got output for that...
If u have created user interface( Avalon-mm) for EMIF IP..if so possible can u share the file?
Hi
The traffic generator module is attached in the design which interfacing to DDR4 EMIF IP via Avalon-mm.
the module path is here
qii/ip/ed_synth/ed_synth_tg/synth/ed_synth_tg.v
Ya correct...I am asking user interface vhdl code(Avalon mm) to interface with EMIF IP
Need to remove tg and include user interface code..
