6457 Discussions
Can I use USB Blaster w/ Cyclone 10 LP Eval Kit?
AZeli
I am trying to connect USB Blaster to Cyclone 10 LP eval kit directly. Is it possible? i cannot connect to the EPCQ device.
AnandRaj_S_Intel
Hi AZeli,
we can connect USB blaster to Cyclone 10 LP eval kit but.
  1. USB Blaster Programming J2 Header uses JTAG mode only.
  2. To connect it to EPCQ we need to use build in USB blaster using USB connector J17.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
AZeli
Thank you for the response.
I connected a USB blaster to J2 and scanned the chain. I see two devices - the FPGA and a virtual device. I didn't see the CPLD on the chain, which led me to suspect that there is a separate JTAG chain for it. I think I also figured out the EPCQ already.
Is there a way to eliminate the virtual device from the chain?
AnandRaj_S_Intel
Hi AZeli,
Yes, can eliminate the virtual device from the chain using DIP switch SW1.
SW1.4 Logic 0 = Vitual JTAG Bypass
Logic 1 = Vitual JTAG Enable
Anand
