- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
We have developed an ethernet driver for Cyclone V SoC in bare-metal programming. When we are transmitting more than 80 bytes per packet in our customized board it is getting failed. But the board can receive up to 1200 bytes in a packet.
We have used the UDP protocol.
I have tried pinging the IP with 100bytes ethernet getting unresponsive.
we have taken the Arria10 driver as a reference and LWIP 2.0.3 as IP stack.
We have KSZ9021RN PHY IC and configured as 10/100 Ethernet speed.
Checked the tx and RX descriptor's size and packet length and found them adequate for 1024 bytes. I have attached the code.
Seeking help from the experts.
Kindly do the needful.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Aik Eu,
The above issue is soved. Some macros related to dma configuration are commanded in code. After removing the command it is solved.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ranjithkumar828,
I will try to consult and see if there is any information which might help to answer your question.
Aik Eu
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Aik Eu,
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ranjithkumar828..
Could you share the driver you created to send/receive UDP packets from the ethernet port?
I'm trying to do the same thing you did but with a DE10 nano board, for now without success, because I can't find a baremetal driver on the internet that allows me to use the ethernet port to send simple raw packets.
Would you be willing to give me some help?
Thank you,
Luca.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Aikeu,
As i sent mail, When we trying to boot from QSPI few interface like Etherenet and OLED (SPI) is not working. Please check that and provide solution for the same.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ranjithkumar828,
I think you will require to create another case related to the QSPI booting Ethernet and OLED function was not working for tracking purpose.
Aik Eu
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ranjithkumar828,
Try to enable one ethernet or OLED function at a time for your system to boot up. This might help to see if those are related to timing issue due to initialization when perform QSPI boot up.
Aik Eu
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ranjithkumar828,
I am closing this thread for now. Do consider open a new thread for the to other issues that you have mentioned.
Aik Eu
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
