6478 Discussions
Cyclone V Transceiver Native PHY IP Core
S_Healthineers
Hello, by the Cyclone V Transceiver Native PHY IP Core is the Transceiver Reconfiguration Controller optional ? can i left the Reconfiguration output signals Open and the inputs putted to zero.
PS . I don't need  to dynamically change reference clocks, PLL connectivity, and the channel configurations at runtime.
SengKok_L_Intel
Even if there are no reconfigurations at runtime, this still needs to connect the Transceiver Reconfiguration controller to the Native PHY. You can't just leave it open without connecting or put to zero.
Regards -SK
S_Healthineers
Thanks for the quick response SK Lim,
is it enough if I connect  the transceiver with the reconfiguration controller and control only  the mgmt_clk_clk  and mgmt_rst_reset ? or i have to do also something with the communication interface read/write ?
SengKok_L_Intel
​Yes, you just need to hook up the signals accordingly, and control only the clk and reset signals will do.
Regards -SK Lim
S_Healthineers
