5941 Discussions
DDR4 controller DQS pins
User1580871742356367
I wonder if the polarity of DQS signal can be inverted inside FPGA (not HPS), for example, bank 3F or 3H.
The DQS_P and DQS_N connection are reversed at one DDR4 device side and there 4 DDR4 devices forming a 64 bit memory bank.
Hope to hear from ASAP. Thank you.
AdzimZM_Intel
Hi Sir,
Thanks for posting your question in Intel Community.
Unfortunately, you cannot change the polarity of the DQS signal.
Adzim
Hi Adzim,
Appreciate quick response.
I know the DQS P/N pins can not be changed or swapped.
I meant inverting DQS in the VHDL or Verilog code, for example, somewhere in the MIG, like put a NOT gate.
ASAP, thank you.
AdzimZM_Intel
Hi Sir,
I don't think you can do that due to timing related issue.
Besides, the signals are harden circuitry that you not able to change it.
Adzim
sstrell
I'm presuming you're using a hard controller and PHY.  If so, no, you can't do that.  You wouldn't want to either due to extra delay.
