6472 Discussions
[DE1] Making the VGA works with the IP VGA Controller
Hi all,
I have a question about the DE1 Board.
These day i am working on a project with SOPC and Nios II.
My objective is to control DE1 feature directly in C with the Eclispe tools.
Actually i can successfully control Led, Key , Switch , SEG7 , SDRAM and SRAM.
Did Someone have a working exemple for control the VGA with Nios II ?
I have tested with this IP :
http://www.altera.com/support/refdesigns/sys-sol/computing/ref-niosii-vga.html
VGA works but pixel coordinate aren't displayed properly ( picture attachement exemple)
i wanted to display a 5x20 yellow rectangle at X=20 Y=20
Did you can help me to make this good strarting point for everyone want to use a simpliest way to control that Card :)
Thanks a lot
Hi all!
I'm new in DE1 KIT.
I'm building a SoC that displaying data from SDRAM into he screen through VGA.
My SoC contents:
- Nios II
- On-Chip Memory
-JTAG-UART
- System ID
- SDRAM
- VGA
I want to display data from SDRAM to VGA by using DMA for reading data from SDRAM to VGA. My C program write data to SDRAM by NIOS. Then I use DMA to read data from SDRAM to VGA. When the interrupt occur, DMA will read 640 value (1 line) from SDRAM to VGA.
My VGA core has a FIFO to buffer data. When fifo is empty, the VGA core will make a interrupt signal to control the transferring of DMA.
My system has some problems such as:
- First: When I use NIOS II to verify the read, write of SDRAM, it operates unstablely. I use "for" loop to write and read data to SDRAM but it just correct in the first 154 values
- Second: When the interrupt occur, DMA only operates within two loop, in third loop, DMA reports the error : "Can post request..."
Anybody can help me. please!
Thanks so much!
