6373 Discussions
DE10-Lite board not recognized by ControlPanel and Quartus.
YN1
The USB Blaster driver was installed correctly.
However:
1. The Control-Panel application pops the attached message.
2. Quartus is unable to detect the hardware, the Processing->Autodetect is shaded and JTag Auto detect return an error (82) .
hope anyone encountered the same problem..
  • DE10-Lite board from Terasic
  • Windows 10
  • Quartus 18.1
  • Control Panel 1.0.3.0
CalvinJoaz_P_Intel
Hi Yaniv Nana, Good day. This might be a tool problem with Windows 10 and/or newer Quartus version. Did you tried in Windows 7? Kindly refer old thread below with similar issue has been solved with Windows7. https://forums.intel.com/s/question/0D50P00003yyPtmSAE/trouble-running-the-de2115-system-cd-control-panel-displays-error Thank you.
YN1
Hi Calvin Joazer,
Thanks for replaying and referencing to similar problem.
As it is, i solved it by doing the following:
  1. uninstall Quartus 18.1 and installing instead Quartus 15.1.2
  2. installing new bin32\ received from Teasic representative (did try the link in the user manual with no success).
I cannot claim conclusively which of the steps solved my problem.
But the ControlPanel.exe runs well on Windows10 + Quartus15.1.2
YN
Unicorn7141
Hey, I know it's been forever but do u happen to still have the files sent to you by terasic?
CalvinJoaz_P_Intel
Hi Yaniv Nana, Glad you have resolved the issue and thank you for sharing the solution as well. Thank you.
