6478 Discussions
De10-standard:U-boot for my personal design issue
CAlex
New Contributor II
Environment:
Quartus Prime Lite 22.1std
SOCEDS standard 20.1
Host computer: Windows 11 with WSL2 ubuntu 20.04 LTS /python 3.9.1-arm64
I made a design with my personal IP in it.
And try to build the u-boot based on that.
I'm following the instruction on rocketboard.org:
Here is the link:
Building Bootloader for Cyclone V and Arria 10 | Documentation | RocketBoards.org
And this error occured:
Could you guys please help me fix that?
EBERLAZARE_I_Intel
Yeah for that issue need to do this:
To resolve the NameError: name 'unicode' is not defined, replace the occurrence of "unicode()" with "str()". This issue occurs because unicode() was renamed to str() in Python 3.
Locate the unicode() in "cv_example.sdmmc/cv_soc_devkit_ghrd/software/bootloader/u-boot-socfpga/arch/arm/mach-socfpga/cv_bsp_generator/hps.py"
Then replace the unicode with str, for e.g.:
from
...( unicode("const u8 sys_mgr_init_table[] = {\n"))...
to
...( str("const u8 sys_mgr_init_table[] = {\n"))...
From my last experience these two seem to be the only issue I faced last time, it should be good after.
Thanks for your feedback! Yeah we are investigating the Python version for this and will fix the issue for future versions. We apologize for any inconvenience.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
EBERLAZARE_I_Intel
Can you find the file mentioned in the error, hps.py you can locate it as mentioned in the error, the directory.
In the hps.py in the line "537" change it to this and re-try:
print ("***Error:Found unexpected HPS child node:%s" % childNode.nodeName)
CAlex
New Contributor II
Good news is that fixed that syntax problem.
Bad news is there are many new error:
regurads.
CAlex
New Contributor II
BTW, my python version is 3.9.1-arm64 because the python SOC have in host-tool cause the bsp-editor warning.(I'm working on CyClone V so I must use bsp-editor)
EBERLAZARE_I_Intel
from
to
EBERLAZARE_I_Intel
Do you have any further questions related to this thread?
CAlex
New Contributor II
EBERLAZARE_I_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
