6472 Discussions
Does 120 ohm pull up with LED indication work for CONF_DONE for 5AGXMB1 FPGA?
SKacc
As per datasheet, 10K is recommended to pull up for CONF_DONE. Attached the circuit followed in our product.
NurAiman_M_Intel
Hi SKacc,
Thank you for contacting Intel community.
Intel recommended 10k to pull up for CONF_DONE. 120 ohm can be use, but Intel will not be responsible if it is not working for the device. Hence it is better to follow Intel's guidelines.
Thank you.
Aim
SKacc
Hi Aim
Is there any other method for FPGA configuration status visual indication?
Srikanth Kacchu
NurAiman_M_Intel
Hi Srikanth Kacchu,
Usually we used LED to see the status. The LED will turn green after the conf is done. Below is the example by using Cyclone 10:
Aim
NurAiman_M_Intel
I am having an error to insert image in here, hence please look in your private message in forum for the image.
Aim
SKacc
Hi Aim
I couldn't find the image in My Messages. Can you able to send any link?
Srikanth Kacchu
NurAiman_M_Intel
I have sent the message again. Please check.
Aim
SKacc
Hi Aim
Where can I see your message? If possible, please share the information to my mail kacchu.srikanth@hcl.com.
Srikanth Kacchu
