5953 Discussions
EPCQ remaining space read and write
adamShiau
Hello everyone,
I am using the Cyclone IV model FPGA and utilizing a 16Mb EPCQ to store a .jic file.
If there is any remaining space in my EPCQ,
I would like to use it for storing some parameters.
Could you please guide me on how to determine the amount of available space?
Thanks!
Adam.S
KellyJialin_Goh
You may refer to the EPCQ flash data sheet to understand more on the memory space of a .jic file occupying the EPCQ flash: https://www.mouser.com/datasheet/2/612/cfg_cf52012-1301744.pdf
Thank you.
Kelly
FvM
Valued Contributor III
a straightforward approach would be to reserve the memory amount specified for maximal uncompressed configuration file size in device handbook, rounded up to full flash sector. Use the remaining flash blocks for other purposes.
adamShiau
Hi FvM,
How can I determine how much space the .jic file has occupied in flash? Information like the start address and end address, for example.
Adam. S
FvM
Programming File Converter optionally generates a map file with this information.
adamShiau
Hi FvM,
In my application, the size of `.jic` file is 2MB.
I convert the `.sof` and `.elf` files into `.flash` files separately,
and then further convert them into `hw.hex` and `sw.hex` files.
Afterward, I combine these two `.hex` files into a `.jic` file.
Upon completing the conversion, I obtain a `.map` file,
with content containing information from `hw.hex` and `sw.hex` (as shown below).
My question is, if this content represents the address information in the EPCQ,
why is there such a significant difference in file sizes?
0x3BA05 corresponds to 244,229 Bytes, which is only 238.5KB.
Adam S
KellyJialin_Goh
Greetings and welcome to Intel's forum.
You may find more information on the .jic file information generated here: https://www.intel.com/content/www/us/en/docs/programmable/683299/current/generating-jic-and-jam-programming-files.html
Thank you.
Kelly Jialin, GOH
adamShiau
Hi Kelly,
Thank you for your response.
However, the link doesn't mention the information about .jic file content occupying EPCQ addresses.
It's more like a guide about file conversion.
Adam S
KellyJialin_Goh
Any updates from your end whether the information provided was useful?
Thank you.
Kelly
KellyJialin_Goh
Any updates on the issue? Is there any further support needed from my end?
Thank you.
Kelly
KellyJialin_Goh
Thank you.
Kelly
EBERLAZARE_I_Intel
Do you have any further questions?
JingyangTeh
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
