6231 Discussions
Error (10822): HDL error at triangular_carrier.vhd(21): couldn't implement registers for assignments on this clock edge
mho12
THERE have some error of my code
but i don't know how to slove this problem
can anyone help me to correct my code
thank you so much !
this is the errror message i had:
this is my code:
entity triangular_carrier is
architecture Behavioral of triangular_carrier is
signal x,y:INTEGER:=0;
begin
process(clk,Ts)
begin
case x is
when 0 =>if (clk'event and clk='1') then    <---- there is my error occured
if y/=(Ts/2)then carrier <=y+1; y<=y+1;
else x<=1;carrier<=y-1;y<=y-1;
end if;
end if;
when 1 =>if (clk'event and clk='1') then
if y/=0then carrier <=y-1; y<=y-1;
else x<=0;carrier <=y+1; y<=y+1;
end if ;
end if;
when others=>null;
end case;
end process;
end Behavioral;
SreekumarR_G_Intel
Hello Mark , In the HDL , every statement /code you write it will be good to make sure what hardware it can be realized or infer too. In most of the case synthesis tool behave very similar. For example lets take the above RTL,Case statement usually realized hardware as multiplexer ,..Now question is how you can implement multiplexer with synchronous logic, which is not possible right ?. that is why tool giving a statement " Cant implement the register logic(clocked logic) on this assignment" make sense? I would modify your code as below , if(rising_edge (clk) and clk = 1 ) then Case x is when 0 => when 1 => etc... Thank you , Regards, Sree
mho12
i revised the code as you teach me
but i have this error message below:
Error (10500): VHDL syntax error at triangular_carrier.vhd(33) near text "process"; expecting "if"
there is the code i revised :
begin
process(clk,Ts)
begin
case x is
when 0 =>
end if;
when 1 =>
if y/=0 then carrier <=y-1; y<=y-1;
end if ;
when others=>null;
end case;
end process;
end Behavioral;
would you tell me where am i wrong
thank you so much
mho12
or can i change the code like this
is this same meaning of my code?
begin
process(clk,Ts)
begin
case x is
when 0 =>if (clk='1') then
end if;
end if;
when 1 =>if (clk='1') then
end if ;
end if;
when others=>null;
end case;
end process;
end Behavioral;
SreekumarR_G_Intel
Hello Mark,
i am not sure about above code ..it looks same to my previous one ? ..can I ask what you trying to implement ? If you give me detail info I can try to help you out ?
Thank you ,
Sree
mho12
when i foolow your steps then revise my code as you teach
it will have this error message :
And this is the code which i revised
begin
process(clk,Ts)
begin
case x is
when 0 =>
end if;
when 1 =>
end if ;
when others=>null;
end case;
end process;
end Behavioral;
SreekumarR_G_Intel
Hello Mark,
Here is the modified code ,
you added the if condition for clk, but didnt add the end if .If it is not confidential ,and let me know what logic you plan to implement i cna help you out if i can ?
begin
process(clk,Ts)
begin
case x is
when 0 =>
if y/=(Ts/2)then
else
x<=1;
carrier<=y-1;
y<=y-1;
end if;
when 1 =>
if y/=0 then
else
x<=0;
carrier <=y+1;
y<=y+1;
end if ;
when others=>null;
end case;
end if; -- Endif here misisng.
end process;
end Behavioral;
Thank you ,
regards,
Sree
SreekumarR_G_Intel
Hello Mark, Can you let me know any further question on this topic , if not can you kindly close the case ? Thank you, Regards, Sree
